I am getting 0x00000027 error in Windows Server 2008 R2 whenever I am trying to access any shared resource in the network. I will be very grateful if someone can help me out in solving this error.
How To Fix 0x00000027 Error In Windows Server 2008 R2?
There can be many reasons for the 0x00000027 error in Windows Server 2008 R2. Try out these methods to solve this error –
Method 1-
Check the disk where your OS is installed. If it is running low on space, you need to allocate space to it.
Method 2-
It may happen your RAM is unable to handle network load. Follow these steps to check your RAM-
a. Type Windows Memory Diagnostic in the start search menu and open it.
b. Click on the option shown in the figure.
c. If the test fails, you should upgrade your RAM.
Method 3-
Try updating your driver –
a. Right-click on This PC and open Manage.
b. Go to Device Manager.
c. Open Display drivers and update the driver.
d. Restart your device.
