How To Fix 0x0000005 Chrome Error?
I have been facing issues while running chrome. My app crashes with 0x0000005 chrome error. I am unable to use chrome. Here is a screenshot of the error.
0x0000005 chrome error can be fixed easily by using these methods-
Method 1
a. Right-click on your desktop chrome icon.
b. Go to properties.
c. Find the target input box under the shortcut tab.
d. In the end, type –no-sandbox.
e. Apply->Ok.
Try to run your application.
Method 2-
You need to uninstall and again install Google Chrome using some other Browser.
a. Press Windows + R, type appwiz.cpl in the Run dialogue box.
b. Right-click on Google and uninstall it.
c. Open Internet Explorer or any other browser.
d. Type Chrome Download.
e. Download the file and run it to install chrome.
Now, you will be able to use chrome.
Notifications
