How To Fix 0x000000c5, 0x000000be And 0x000000c2 Error
Hi, Guys! I was stuck on this 0x000000c5, 0x000000be, and 0x000000c2 error message while starting my computer. Can anyone tell me what could have caused it and how to fix it?
A) This 0x000000c5, 0x000000be, and 0x000000c2 error could cause due to several reasons like driver incompatibility, misconfiguration, and so on. To fix it, you need to go to the command prompt in the safe mode of the windows and type chkdsk/f/r and hit enter. It will scan the hard disk for error and will fix it.
B) This 0x000000c5, 0x000000be, and 0x000000c2 error could cause due to several reasons like driver incompatibility, misconfiguration, and so on. To fix it, you need to update the drivers to the latest version by going to control panel and then go to the Device Manager. Select the drivers that you want to update by going inside the properties of it by right-clicking on them. Now choose the option of update driver and the windows will search, download, and then install the latest version for it. It will fix your issue.
