How To Fix 0x19_bad_pool_header Error?
Hello guys, there is a problem with my PC it shuts down automatically when a big blue screen appears saying that error 0x19_bad_pool_header. Please help me to fix it. Thank you.
Hey, learners. Have trouble in fixing 0x19_bad_pool_header error? Then follow the steps to fix it.
Usually, 0x19_bad_pool_header error occurs due to hardware or software issues, or due to failed windows update, it will be solved by troubleshooting.
Method 1: Fixing the error using a repair tool.
• Step 1: Download the repair tool from the browser.
• Step 2: Follow the prompts and install the program, on the welcome screen, untick the automatic scan option.
• Step 3: Click on install.
• Step 4: After installation, the software will scan your PC automatically and show the damaged areas in your PC, which has to be fixed. Click on Repair.
• Step 5: Restart your PC.
Method 2: Fixing the error using the system restore technique.
• Step 1: On the windows search icon hit enter.
• Step 2: Enter system restore in the search box.
• Step 3: Click on system restore and follow the prompts.
Thank you.
