How To Fix 0x2 Bdf5f Error?
Hello, I am getting an error code 0x2 bdf5f showing “OneNote couldn’t sync” while I’m trying to install and access notes in Microsoft OneNote. Please help me to fix this. Thank you.
Hello guys, “worried about 0x2 bdf5f error?”. Don’t worry; just follow the below instructions to resolve the error.
“0x2 bdf5f – OneNote couldn’t sync” usually, this occurs in the following situations.
Cause:
• Microsoft OneNote is not been installed appropriately.
• Files of the existing version might be corrupt.
• The previously installed program was not uninstalled correctly.
• If you’re using the older version.
Methods to resolve the issue are:
Method 1:
Troubleshooting the error using a repair tool. This helps you in removing all the corrupted files and fix the error.
• Step 1: Open command prompt.
• Step 2: Run it as an administrator.
• Step 3: Now, in the command prompt, enter “SFC/scan now” and click on Enter.
Method 2:
Check for updates, sometimes the error may occur due to failed updates.
• Step 1: Check for the registry keys of the software in its properties, and try opening it again. If the problem persists, then follow the next step.
• Step 2: Go to settings, go to update and security, then click on windows updates.
• Step 3: Click on check-updates, wait for your PC to check and if any updates are found to update them and restart your PC.
If the problem persists still, then it’s better to uninstall and reinstall the software again. To install the software properly, follow the below method.
Method 3:
Installing Microsoft Office.
• Step 1: Go to the browser, sign in to your Microsoft account, select Microsoft Office, check the latest version, and download it.
• Step 2: Click on install.
• Step 3: Follow the prompts, and after a few clicks, your Microsoft Office will successfully install and will be ready to use.
One can use these methods for any version of Windows.
