Hello experts, I have been using task scheduler for many years recently while I’m trying to run it manually or schedule a task from it, every time 0x2 error in task scheduler occurs. Please help me out to fix it.
How To Fix 0x2 Error In The Task Scheduler?
Hello. You need not worry about fixing 0x2 error in the task scheduler; it’s quite easy to fix it, all you need to do is just follow the below-mentioned methods.
To fix any error, one needs to know the cause of it.
What is it? What is the cause of the 0x2 error in the task scheduler?
The task scheduler executes the .bat or .cmd file, which has to be performed by the administrator, to save the time from scheduling them daily the administrator gives the access to the administrative rights to run the tasks from the assigned account. Even though the rights have been given, sometimes it fails to perform the duty resulting in the last run result of 0x2 is failed because access has been denied.
Methods to fix it:
Method 1:
Fixing the error using a repair tool.
• Step 1: Download the repair tool from the browser.
• Step 2: Follow the prompts and install the program, on the welcome screen, untick the automatic scan option.
• Step 3: Click on install.
• Step 4: After installation, the software will scan your PC automatically and show the damaged areas in your PC, which has to be fixed. Click on Repair.
• Step 5: Restart your PC.
Method 2:
This method will help you to override the properties with the least privileges and allows the tasks to run.
• Step 1: Double click on the task, go to properties.
• Step 2: Change it to Run with highest privileges click on ok.
• Step 3: Enter the password.
