I am trying to sync my mail with the Windows 10 Mail App, but I am experiencing a 0x8000000b error. I do not know the solution to this. Please help me in solving this, and thanking you in anticipation.
How To Fix 0x8000000b Error In Windows Mail App?
Hi, you are in the right place with your issue. I will help you to solve the 0x8000000b error. Try out the following methods –
Method 1-
a. Open Windows settings (Shortcut – Windows key + I).
b. Open Apps-> Apps & Features.
c. Search Mail in the search list.
d. Click on it.
e. Click on Advanced Options.
f. Click on Reset.
g. Complete the process.
h. You will be able to sync your mail now.
Method 2
a. In the Window’s search box, type Windows Defender Firewall.
b. Open it.
c. Click on Turn Windows Firewall on or off.
d. Turn off the firewall for both the public and private networks.
e. Sync your mail.
f. Follow the same steps and turn on the firewall.
