Hi, I currently signed in to the Mail app in Windows 10, but the App does not sync properly. I cannot see the latest messages. When I try to sync manually, I get a 0x80070003 Mail app error. How to fix this issue?
How To Fix 0x80070003 Mail App Error In Windows 10?
The most common way to fix the 0x80070003 Mail app error in Windows 10 is to Update Windows.
a. Search Update in the Window’s search box and open it.
b. Install the latest Windows version, and sync your Mail.
If updating the Windows did not help, try the below method –
a. Open the Mail App.
b. Go to Settings.
c. Open Accounts.
d. You need to choose the account that you have to sync.
e. Go to Change mailbox sync settings.
f. Select the Email option.
