When I was installing .NET framework 4 in my Windows 7 Professional laptop, I encountered a 0x80070659 error. It says that the installation is forbidden by system policies. How can I fix my issue?
How To Fix 0x80070659 Error In Windows 7 Professional?
You can fix the 0x80070659 error by using an administrator account. If you are already using an administrator account, try the methods given below –
Method 1
1. Right-click on the installer file (.exe).
2. Click on Run as Administrator.
3. Proceed with the installation process.
Method 2
1. Open Control Panel.
2. Open Administrative Tools.
3. Go to Local Security Settings.
4. Click the Software Restrictions policy.
5. If you see that no restrictions are there, right-click on the Software Restriction Policies node. Then, select New Software Restriction Policy.
6. Double-click on the Enforcement.
7. Select the option – All users except local administrators.
8. Click OK.
9. Restart your device.
10. Proceed with the installation.
