How To Fix 0x800b010e Error In Windows 10?
I upgraded from Windows 7 to Windows 10, and then I cannot connect to the internet. I ran the troubleshooter and got a 0x800b010e error. I can connect other devices to the router. How to fix the error?
You can face the 0x800b010e error after upgrading to Windows 10. The following methods will help you to solve the error.
Method 1
a. Open Command Prompt as Admin.
b. Type netsh winsock reset and press enter.
c. Type netsh int ip reset and press enter.
d. Type ipconfig /release and press enter.
e. Type ipconfig /renew and press enter.
f. Type ipconfig /flushdns and press enter.
g. Your internet will work.
Method 2
a. Search Network Reset in the Windows Search Box.
b. Open it.
c. Click on Reset Now.
d. Try to connect to the internet.
