How To Fix 0xc0000005 Error Query
I want to know how to fix 0xc0000005 error on my windows computer. I think this issue is driver related but I am unaware how to fix this problem. If you guys know anything, help me.
To fix the error you are getting-
1. Go to the start menu and then type device manager and then hit enter
2. Then you need to find the driver to be fixed
3. Right click on the driver and update it
4. Let the update complete and be installed.
That’s it. This is how you fix the error.
The other term for error code “0xc0000005” is “Application Error“ or Access Violation. You may receive this when your computer is not able to completely process the files and settings it requires to run a specific application or installation. It is caused by many different things like faulty memory modules, errors in files, and problems with the settings on your computer.
There are many ways to fix this and one is to restore your computer to a previous state. Click “Start,” “All Programs,” “Accessories,” “System Tools,” and then “System Restore.” Select an older restore point then see if this fixes the problem. Another way is to fix problems in the Windows registry. Download PC Tools Performance Toolkit then follow the instructions to download and unpack and then install it.
Once installed, start PC Tools then go to “Performance” tab and click “Clean Your Registry.” Make sure “Complete Registry Scan” is selected then click “Start Scan.” Wait until the scan is complete then repair them. You can also use CCleaner to fix problems with the registry. Go to CCleaner Download then download the free version. Select “Registry” on the left pane and click “Scan for Issues.”
After the scan, click “Fix selected Issues” to fix all the problems found. After this, restart your computer.
Notifications
