I just downloaded and installed a new game on my Windows 7 laptop. I checked the system requirement and my laptop can run this game. But, when I try to start the game, I get some 3dmgamedll dll missing error. How to solve this?
How To Fix 3dmgamedll Dll Windows 7
You are getting a dll file error which is relatively common. The thing is that dll files are not part of the operating system but are required by it to run the programs correctly. DLL files are shared files and are not linked to the programs that install them.
In this case, you are getting the error while launching the game. You need to check the version of directX installed on your computer. In case it is not the latest version, update it. If this doesn’t solve the problem, find and download the missing dll file and install it on your computer and place it in the system folder of your computer.
