How To Fix 8003 Error On Mac?
I have a Macbook. When I try to delete files from the Trash or attempt to empty trash, I encounter an 8003 error. How to fix it?
Method 1
a. Press the option key.
b. Click on Empty trash while holding the option key.
Method 2
a. Open the Trash folder.
b. Right-click on the file that is causing the problem.
c. Open Get Info.
d. Open the Sharing and Permissions heading.
e. You need to enable the Read/ Write Permissions.
f. Try to delete the file/ empty Trash now.
Method 3
a. Go to Applications -> Utilities.
b. Open Terminal.
c. Type sudo rm -rf and hit enter.
d. You may need to enter your password.
e. Drag the file that is causing the trouble from the Trash folder to the terminal.
f. Hit enter.
