How To Fix A 0x204 Error In Windows 10?
I am unable to give remote access to my Windows 10 PC to my colleague. I am encountering a 0x204 error. I am unable to fix this. Please help me.
Follow these methods to fix the 0x204 error.
Method 1-
a. Press Windows + R.
b. Type SystemPropertiesRemote.exe and hit enter.
c. Go to the Remote tab.
d. Match your settings with this image.
e. Apply->OK.
f. Try to give remote access to your PC.
Method 2-
a. Search Control panel in the start menu and open it.
b. Click on System and Security.
c. Click on Allow an app through Windows Firewall.
d. Locate your app in the list.
e. Enable both private and public options.
f. Apply->OK.
g. Try to give remote access to your device.
