How To Fix Advapi32 Dll Error Windows 7
When using my computer, I randomly get an error message saying advapi32 dll missing. I cannot seem to find any visual effects that this error is having on my computer but getting this error, again and again, has got me concerned. How to remove this problem?
Answered By 0 points N/A #322953
The advapi32.dll file is a DLL file associated with the Microsoft API Services Library. This is an essential file and is required for the normal functioning of Windows. DLL files are used by the operating system to run the programs installed by the user on the computer correctly. Therefore, DLL files are very important for the system.
To remove this error, all you need to do is replace this file in the systems folder of your computer. Find the missing dll file on the internet. Download the file and place it in the Systems folder. Restart the computer and the error should be gone.
Answered By 590495 points N/A #328603
The full error reads:
“STOP: c0000135 {Unable To Locate Component}
This application has failed to start because ADVAPI32.dll was not found. Re-installing the application may fix this problem.”
The “advapi32.dll” file is located in “C:\Windows\System32” by default. This DLL file provides advanced Windows API functions related to Windows registry, applications, user accounts, and services. On Windows 7, you can try fixing it using the System File Checker utility. Insert your Windows 7 installation DVD on your optical drive then restart the computer and boot from the DVD.
On the Windows 7 installation DVD, select the language you want to use, time, and keyboard. Select “Repair your computer” then select drive C or the drive where Windows is installed and then click “Next.” In “System Recovery Options” screen, select “Command Prompt.” In the command prompt, type the following command then hit Enter:
sfc /scannow /offbootdir=C:\ /offwindir=C:\Windows\
This should fix the problem.
