Becx Taylor
Posted on - 08/22/2019
The majority of all the errors that I have encountered on my computer are dll errors or have something to do with dll files. I was wondering if there is a universal solution that works for all dll errors? How to fix all dll errors?
How To Fix All Dll Errors Windows
A lot of users experience dll file errors at some point or the other while using their computers. Dll files are actually shared files that are not part of the OS because multiple programs use these files. Therefore, dll files are not linked to the programs and are shared by them. These are essential for your computer to work properly.
DLL errors occur due to missing or corrupt dll files. To resolve these errors, the simplest method is to find the missing dll file no the internet and downloading it. Then place the dll file in the system folder of your computer. This solves a majority of dll errors.
Regarding DLL errors, the usual remedy is to uninstall and reinstall the program where you encountered the DLL error. The usual problem encountered when comes to DLL file is that the file is either missing or invalid. It is easy to identify which file has a problem because it is, most of the time, indicated in the error message.
So, just locate the DLL file in question on the installation folder. If the DLL file is not missing then it means the file is corrupted. In this case, reinstalling the application should fix the problem. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select the affected or faulty program among the applications and click “Uninstall”.
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then install the program back. If this doesn’t work, install the latest version because it could be related to compatibility.
