How To Fix Android Winusb 64 Bit
I connected my phone to my computer via USB. When I got the USB options on my phone, I saw a new one called adb debugging. I was curious so I selected that and the computer started giving me android winusb 64-bit error. What to do?
Answered By 40 points N/A #324162
You need to have the Google USB driver for Windows if you want to perform  adb debugging. As far as adb is concerned, adb stands for Android Debug Bridge which is nothing tool that you can use on the command line to communicate with your phone from your computer. It is used by developers, ethical hackers, and advanced users to debug issues with phones.
You can download the USB driver from the internet or you can find it in the SDK manager in the Android Studio Client. Once you download the file, extract all packages and you will be able to perform adb debugging.
