How To Fix Bttray Exe Application Error
When I try to connect anything to my computer using BlueTooth, I get the bttray exe application error and then the device fails to connect to my computer. I am facing this issue for several days now. How should I proceed with this?
Answered By 10 points N/A #322220
The problem here is that your computer’s BlueTooth stops working after the bttray.exe application error and therefore no device is able to connect to your computer via BlueTooth. Bttry.exe is associated with a Bluetooth Tray Application. This basically makes it easier to identify and manage Bluetooth devices connected to your computer.
To fix this problem, uninstall the program and then reinstall it. See if this removes the error. If this does not fix the problem, then conduct a system scan of your entire computer to make sure you are not infected with any virus or malware. Once you have done this, clear all system registry and try again. This should solve your problem.
