How To Fix Dell Inspiron 1545 Lcd Screen No Display?
When I switch on my laptop, the power led is turned on but there is no display on the LCD screen. How to fix dell inspiron 1545 LCD screen no display problem?
To fix dell inspiron 1545 LCD screen no display problem, you can try the following steps –
Method 1
1 – Power off your PC.
2 – Remove the charger.
3 – Remove the battery.
4 – Press and hold the power button for 20 seconds.
5 – Plug in the charger and battery.
6 – Switch it on.
Try the below methods if this does not work.
Method 2 –
Try to clean the RAM by opening the back cover of your PC.
Method 3 –
Connect your laptop to an external LCD and see whether it is working. If it is working, then there is a problem with your motherboard and it needs to be replaced.
