I recently installed the Lord Of The Rings video game on my Windows 7 computer. I meet all the system requirements mentioned on the website so the game should work on my computer. However, when I try to run the game it gives me divxdecoder dll download error. How to solve this?
DLL or Dynamic Link Libraries are files that are used by Windows to run certain programs on it. These are shared files and therefore they are not associated with the programs that installed them on your system.
To remove this error, all you need to do is to find this dll file, download it and place it in the appropriate folder. I must strongly advise you to only download files over the internet from websites that you trust to be safe. This is because there is always a risk of getting infected with viruses and malware when downloading files from the internet. If you do not have an antivirus, I would strongly suggest you against it.
I’m not sure if you are referring to the right game, “The Lord of the Rings Online,” because that error was triggered by “Wow.exe” which is probably “World of Warcraft.” Anyway, check the system requirements and verify your computer meets those requirements. “The Lord of the Rings Online” supports Windows XP Service Pack 2 and higher.
It requires 3 GHz or faster Intel Pentium 4 or equivalent AMD processor, 1 GB RAM for Windows XP and 2 GB for Windows Vista, 12 GB free space, Microsoft DirectX 9.0c-compatible video card with 128 MB video RAM, sound card, and cable or DSL internet connection. If this is not the problem as the game is perfectly compatible, download the free version of Revo Uninstaller and install.
Once installed, start Revo then select the game among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and click to delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then restart the computer.
After booting, disable your antivirus then install the game back. Note: when running the game for the first time and when updating, make sure your antivirus is disabled.
1....
