I am trying to install a game in my Windows 10, and I keep getting error 1603 during installation. I have already tried rebooting my PC, and no antivirus is blocking the installation? How to fix this error?
How To Fix Error 1603 During Installation Of A Program In Windows 10?
You can try these methods to solve error 1603 during installation in Windows –
1 – Check if you have any earlier version of the game you are trying to install. If yes, then uninstall that file and try installing your game again. To uninstall a program in Windows, follow these steps –
A. Press Window key + R to open the run dialogue box.
B. Type “appwiz.cpl” and hit enter.
C. Right-click on the program and click on uninstall.
2 – Delete the temporary files.
3 – Check if you have enough space in your hard-drive. This may sound silly, but we sometimes overlook this step.
