How To Fix Error 522 Connection Timed Out?
I am the operator of a website, and recently, I am getting error 522 connection timed out. I need to solve this out quickly. I will be very grateful for immediate help.
It looks like your server is blocking Cloudflare requests. Try out the following steps –
1 – Check your .htaccess and similar files. Make sure these are not blocking Cloudflare requests.
2 – Check whether your web server is blocking Cloudflare’s IP addresses. Check whether your firewall is blocking any IP address, which is a request from Cloudflare.
3 – Contact your hosting provider and find out if there are any issues from their end.
If these methods do not solve your problem, contact Cloudflare support immediately.
