My laptop was working fine until today. Today, when I started my laptop I got the error code 0x000000d and the message said that I will require recovery media to recover the system. I do not know how to proceed with this. Can you help?
milodiaz
10 points
How To Fix Error Code 0x000000d Windows 10
Computers use error codes to tell programmers and technicians what is wrong with the system and the reason behind the error. The error code, in this case, indicates that you have some corrupt files on your system. This can happen due to incomplete installation of a program or if your system is infected by a virus.
To deal with system recovery can be a tedious process for normal users. If you are not a power user I would suggest that you call up tech support or the laptop manufacturer and let them handle it. Otherwise, you need to create a boot media and run system recovery from the command prompt.
