How To Fix Error Code 0x8024a105
I haven’t been able to install automatic Windows Updates on my Windows 10 PC. I keep getting error code 0x8024a105 before the updates finish. I have tried installing after disabling the firewall and antivirus, but this has not worked for me. Can I resolve this issue?
Answered By 0 points N/A #322212
Thanks for mentioning the troubleshooting options you have already tried. Disabling the antivirus and firewall is a very common solution and works for the majority of users that face this issue. This error is usually seen when the system has corrupt or missing system files.
What you need to do is to try using the Windows Updates Troubleshooter and move ahead with the instructions of the result of the troubleshooter. If the troubleshooter is unable to find any problems then you need to reset the Windows Updates Components. This will reinstall any corrupt and missing files on your system.
