How To Fix Error Code 122
I am facing the problem of error code 122 on my computer. can anybody help me to resolve my problem, which type of error this is? Please help!
This is the error of insufficient buffer also known as 0x7A. This message is shown on your machine. This issue Occur due to Registry is invalid or corrupted, virus attacks, the driver is not installed proper, damaged file or corrupt. To solve this fault, make sure to update driver, scan files to avoid the problem use antivirus to remove the virus. Also, try to restore your machine to solve such type of faults.
Try to uninstall and reinstall the printer driver. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select your printer software among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer.
When it is finished, exit Revo then install the printer software back. If this doesn’t work, transfer the USB cable to another USB port. Try using all four USB ports at the back of your CPU to troubleshoot the problem. Try also using a different USB cable because the problem might be with the USB cable connected to your printer.
When printing, make sure the printer is turned on.
Notifications
