How To Fix Error Loading Video YouTube On PC?
Hello experts, I want to know that how can fix the error loading video YouTube on my PC.
I use YouTube a lot but back few days not a single video is loading. Please help me to get through this problem.
Sure, this trouble may occur due to changes in your system or your account through which you are using YouTube.
Solution1
Try to re-sign with the same account on YouTube.
Open YouTube on your system.
Click on the sign-out and try to again sign-in with the same account.
Solution2
Check your internet connection.
Solution3
I have switched to some other network, check your network priority if it is to some lower system.
If you have a problem loading videos on YouTube, it only means you are using an older version or an outdated version of Adobe Flash Player which is the main component required to watch YouTube videos. The videos you see on YouTube are all flash-based. This means you should have Adobe Flash Player installed on your computer that supports your current web browser.
Download the following Flash Player versions on your computer so you can play YouTube videos on any web browser:
Also, make sure you have the latest version of the browser you are using. If you are using Windows XP or Windows Vista and you can’t upgrade to Windows 7 or higher, try to install the very last version of the browser for your operating system.
Notifications
