I have a Windows PC, and when I tried to download Examplify, I got this error “mscvr100”. I do not understand it, so can someone explain and suggest me ways on how to fix error mscvr100 DLL and what exactly is this mscvr100.DLL?
How To Fix Error Mscvr100 DLL And Understanding Its Causes?
MSVCR100.DLL is a dynamic link library file, and it is being used by many programs especially, games. This DLL file is a Microsoft Visual C++ file, and it is being used by applications that were made by using Visual C++. If you get this error, nothing to worry as it is easy to fix by following these steps.
You need to know the version of your Windows; whether it is a 64-bit machine or a 32-bit machine because based on that criteria, you can go to the official Microsoft website and get the Visual C++ update of the DLL file. You will get a set of options, where you can choose the ones that you want to download. If you do not know which ones to download, then you can go ahead and click all the boxes and download them all.
Another way to do so is with the help of Command Prompt. That is, you can copy the DLL file from another computer that is the same version as yours. All you have to do is you need to go to, Command Prompt and you need to run it as an administrator. And in the command prompt type in the following command, “control /name Microsoft.
system“, and press Enter. Do the same thing in the system that you are going to copy the file. You are doing this so that you can be sure that both the systems have the same type. On the other computer open file explorer and go to the system32 folder that is present in the C drive. Here copy the DLL file into a flash drive or external hard drive and paste it onto the same location in your system.
