How To Fix Explorer.exe Error?
Hi, when I open the explorer it gets crash and closes automatically. Can anyone tell me how to fix explorer.exe error?
Let me just show you how to fix explorer.exe error in Windows 10. It works the same for other versions too. Here, I’m going to fix this issue using command-lines as it is so easy to do so. Explorer.exe is nothing but getting error for Windows Explorer.
1. Open Command Prompt or In the search box, type Run and then in the Run wizard, type “cmd”. While opening command prompt with Run wizard open it by clicking on “Run as Administrator”.
2. Now type “dism /online /cleanup-image /restorehealth” and press “Enter”. You can also use /StartComponentC1 instead of /restorehealth.
3. After this process finished, now type “sfc /scannow” and press “Enter”.
The second command-line process may take some time. So check it out and then restart your system.
