How To Fix Fatal System Error?
Hi, I power off my computer forcefully as it suddenly got hanged. Then after some time, I power On the system but the blue screen appeared and showing me an error message. Does someone help me how to fix fatal system error?
Answered By 60 points N/A #332202
Hello, I can tell you how to fix fatal system error as it is easier to solve using the option as the Last Known Good Configuration option or Startup Repair option.
1. While Power On the computer, press function key F8.
2. So the boot screen opens with some details.
3. On that page, click on Last Known Good Configuration or Startup Repair based on your operating system version.
4. As both options help to repair your system and set the default setting as it is. It may restart on its own or else you restart it again.
