How To Fix ‘Find Album Info’ Script Error In Windows Media Player 12
Asked By 5 points N/A Posted on -
I have been using Windows Media Player 12 in my PC for long. The ‘Find Album Info’ function is not working in the application when I click Finish to confirm the right album information a window keeps popping up saying there is a Script Error.  Then the only way to get out is by pressing cancel without updating the music files. This problem has started happening. I have tried Restoring my Music Library, but it’s of no use.
Answered By 10 points N/A #324424
The very first idea that pops up is uninstalling and reinstalling Windows Media Player:
-In the taskbar > click Turn Windows features on or off> in the list of the windows features, clear the checkbox present alongside Windows Media Player> you receive a warning message in a pop-up window. Click Yes to Restart the computer> Once again go to Turn Windows features > in the list, put a checkmark next to Windows Media Player > you will receive a warning message in a pop-up window >Click Yes to restart your computer again.
Another way is by managing add-ons on your IE9, click on currently loaded add-ons and change it to all add-ons and disable the add-on of windows media player application.
