How To Fix ICloud Error 2343 While Uninstalling
Today I tried to uninstall iCloud from my PC and, suddenly it gave me an error code 2343. I tried uninstalling a few more times but could not do it. Can anyone help with this?
The main reason for this error code is due to missing of particular registry folder of that App. This registry issue could be because of the error in the windows update and also due to improper uninstallation.
Now I’ll tell you the proper step by step method of uninstalling iCloud:
• First, go to the taskbar and end the process of iCloud, bonjour and, every other Apple services that are running.
• Go to control panel and uninstall every apple applications that are currently not used.
• Next, uninstall iCloud.
• You can also uninstall bonjour first and then try uninstalling iCloud. And don’t forget to restart your PC.
