How To Fix Igfxtray.exe Error?
Hello, I recently installed an online multiplayer game and when I try to run the game, I receive the following error message
The executable igfxtray is a process that runs on all the systems tied to the Intel graphics. This process helps the user to modify the graphic settings. This process is not tied to the Windows system file, but the process begins when the windows system boots up.
Now let me help you with steps on how to fix igfxtray.exe error:
1. Go to start-> Device Manager
2. Open Display adapter -> Intel Graphics (whatever version you have)
3. Right-click and select properties
4. Select the Drivers tab
5. Click on Update Driver
Once its update, you should be able to enjoy your game. Hopefully, the instruction helps you in solving your issue.
