How to Fix Internet connection error 651 in Windows
Hey.
I am a guy who doesn’t know a lot about computers and recently am encountered by Internet connection error 651 in my windows laptop. If anyone knows how to solve it, please answer ASAP. Thanks to whoever answers.
Best Answer by
Answered By 10 points N/A #328634
regain the connection. urn off your computer (please make sure you have saved all your current work before shutting down your Windows). Turn off your modem and unplug Hi. This is a usual error in windows. Don’t worry. The Internet Connection error 651 may be caused by your PC or modem issue, and there may be something wrong when connecting. So, you can restart your modem and PC/laptop to it from the power source. Unplug all the cables that are connected to the modem and computer. Wait for at least 30 seconds. Then reconnect the cables correctly into your modem and computer. Re-plug your modem with the power source, and turn it on. It should work fine.The missing or outdated network driver can cause the error 651 in your computer, so you should update the network card driver in your Windows to fix Internet Connection error 651. One of the two methods should help you.
