How To Fix Internet Explorer Error 404 In Windows7?
Hello, experts, I’m getting an error message ‘internet explorer error 404,’ while using Windows7. Please suggest me the procedure to fix this fault. Thanks in advance for the help.
Try to repair the Registry Entries related to Error 404. Then scan your system for the Malware and then clean out the system junk. You can use some other software to clean up the waste of the computer.
Update the system’s drivers. Undo all the recent changes to your system. After this uninstall the IE and re-install it. Run Windows system file checker, and then install all the updates. After this perform a clean installation of windows.
It seems this error is different from the usual “404 Page Not Found” error you see when you visit a site because the 404 error you received is related to the crashing of the Microsoft Internet Explorer browser. If the browser crashed after you visited a particular site, restart Microsoft Internet Explorer and try visiting that site again to see if the error repeats.
If your Microsoft Internet Explorer crashed again, visit that site again with a different web browser like Mozilla Firefox, Google Chrome, or Opera. If the error did not appear after changing the browser, try running the System File Checker utility. Click “Start,” “All Programs,” “Accessories” then right-click “Command Prompt” and select “Run as administrator.” In the command prompt window, type without quotes “sfc /scannow” then hit Enter.
Insert your Windows setup CD on your optical drive when you are prompted. If this did not work, try updating Microsoft Internet Explorer or try installing all available Windows Updates.
