How To Fix Kernel32.dll Error?
Hello, I have been trying to access certain applications on my PC but I am unable to open them. I am getting the following error.
Can someone help with how to fix kernel32.dll error?
Hi, let me help you with steps on how to approach this issue and how to fix kernel32dll error.
1. If you have restore point defined already, its best to restore to the Last working condition
2. You can use the System Restore application present on your system to restore by following the system restore wizard
3. If you had recently installed any Microsoft application, try to uninstall the application as it might be causing the issue.
4. The final thing you could try is to Go to start and search fr windows update
5. Click on check for update and install the update
6. Once completed, reboot your PC
Hopefully, by following the above steps, your issue should be resolved
