How To Fix Msvcp100.dll Error
Hello, for the past few days, some applications in my system are not working as expected, it is throwing me some system error.
Can someone help me by guiding me on how to fix msvcp100.dll error?
Answered By 10 points N/A #332221
Hello, let me guide you through the process of how to fix msvcp100.dll error that you are facing. If you are receiving the above error, it means that the application has been developed with a necessity to have visual C++ libraries on your system. It probably means either you have not installed the Visual c++ 2010 or your installed libraries are corrupted or outdated.
To fix this error, you would need to install the Visual C++ libraries or replacing the existing installation.
You can find if it exists already by going to control panel -> add or remove features. In my case, I have the 2013 and the app may require 2010
Uninstall the old version and download the package one by going to Microsoft store.
Your application will now work as desired.
