How To Fix Quattro Pro Runtime Error Instantly
Hi all,
I am using Windows 7 on my Dell laptop. It shows a Quattro Pro runtime error with Visual C++ Runtime Library. Â Is there any way to solve this problem?
Hi all,
Hello, this is a quite common problem in Quattro Pro.
Firstly, try the following fix and check whether it works for you or not:
1) First, close Quattro Pro, then go to Start menu and type ‘regedit’ in the Search box.
2) In the Registry Window, browse this path in the left panel of the dialog box:
HKEY_CURRENT_USER\Software\Corel\User Assistant\13\Recent Work\Quattro Pro\
3) Then, right click on the key ‘Quattro Pro’ and then select ‘Delete.’
4) After that, close the Registry Editor and then open Quattro Pro; finally check if the issue persists.
