How To Fix The 0x080070035 Error?
I am unable to share my drive with another device on the same network. Both machines use the Windows 10 operating system. I get a 0x080070035 error. What is the solution to this?
There are several ways to solve the 0x080070035 error. I will tell you about the most common methods.
Method 1 –
a. Right-click on your drive.
b. Click on Properties.
c. Open the Sharing tab.
d. If the Network path is “Not shared,” click on Advance settings.
e. Click on Share this folder.
f. Type a name.
g. Apply->OK.
Method 2-
a. Type Windows features in the search box near the start menu.
b. Open it.
c. Search for SMB 1.0/CIFS File Sharing Support.
d. Select it.
e. OK.
