How To Fix The 0x80070057 Windows Store Error?
My Windows 10 store is not working properly. I am unable to update any app from there. I am encountering a 0x80070057 Windows store error. Any method is known to fix this?
Here are the most effective methods to fix the 0x80070057 Windows store error.
Method 1
a. Press Windows + R.
b. Type cmd admin and press ctrl + shift + enter to open the command prompt as admin.
c. Type wsreset.exe in the command prompt admin and press enter.
d. Wait for the process to complete.
e. Restart your device.
f. Open Microsoft store and try to update your application.
Method 2
a. In the Windows search box, type location, and open the settings.
b. You will find an option – “Allow apps to access your location.”
c. Turn it on.
d. Scroll down, and find the list of apps that can access your location.
e. If required, give access to the location to the app you need to update.
Method 3
If you have any third-party antivirus/spyware/ransomware, protection app installed, turn it off once, and try to update your application.
