How To Fix The 0x80070643 Windows Update Error?
I checked for Windows update last day, and I encountered a 0x80070643 windows update error. Please, reply with the ways to fix this issue.
0x80070643 Windows update error can occur due to corrupted .NET framework. Methods to fix your issue-
Method 1
a. Go here
b. Download the software.
c. Run the software.
d. Follow the instructions.
e. Now, you will not get the error.
Method 2
a. Open Command Prompt as Admin.
b. Type net stop cryptsvc, and press enter.
c. Type md %systemroot%\system32\catroot2.old, and press enter.
d. Type xcopy %systemroot%\system32\catroot2 %systemroot%\system32\catroot2.old /s, and press enter.
e. Press Windows + R key.
f. Type %systemroot%\system32\catroot2.
g. Delete all the contents inside the catroot2 folder.
h. In the command prompt as admin, type net start cryptsvc, and press enter.
i. Restart your device.
j. Update your Windows.
Notifications
