How To Fix The 0x80072ee2 Activation Error?
Hello, experts. I am getting the 0x80072ee2 activation error while trying to activate Windows 10 on my PC. Please suggest to solve the Windows activation error. Thank you.
Hello, learners. Getting the 0x80072ee2 activation error while trying to activate Windows 10, don’t worry, It is quite an ordinary error faced by many Windows users. The reason for the error is corrupt files or pending updates. Follow the below-mentioned solutions to fix the error.
Method 1:
Windows Update Troubleshooter.
• In the Windows search box, enter Troubleshoot. Click on troubleshooting.
• Select Windows Update and click on the run troubleshooter button.
• In the next prompt, choose the error you want to fix this, or if you wish to skip it, select to ignore it.
Method 2:
Troubleshooting the error using the command prompt. This solution will help you to remove all the corrupted files and fix the error.
• Step 1: Open command prompt.
• Step 2: Run it as an administrator.
• Step 3: Now, in the command prompt, enter “SFC/scan now” and click on Enter.
Notifications
