How To Fix The 0x80072ee5 Error?
Hello. I tried to update the Windows version on my PC, and I got the 0x80072ee5 error displayed on my screen. Suggest a solution to resolve it. Thank you.
Hello. The error 0x80072ee5 occurs due to OS update components. It will stop the user from updating the system. To fix it, follow the below solutions.
Method 1:
Cleaning system files.
• Step 1: Hold Windows key + R, enter “cleanmgr” in the dialogue box, click on ok.
• Step 2: Next, choose the disk clean up.
• Step 3: Click on the Windows drive.
• Step 4: Then, a system scan will begin; wait for it to complete.
• Step 5: Next, leaving the previous windows installation and recycle bin, click on all the options.
• Step 6: Click on, ok.
• Next, clean up the system files by repeating the above steps 1-5.
Method 2:
Remove Temp files.
• Hold Windows key + R, enter “temp” in the dialogue box, click on ok.
• Hold the ctrl key + A+ shift key and click on enter.
• Select the files to apply action and click on continue.
• In the same way, you can delete user %temp% files also.
