How To Fix The 0x800c8101 Outlook Error?
Hello, I have been using Microsoft Outlook so many days, recently I’m facing an error 0x800c8101 Outlook error. I’m not able to deliver and receive any emails. Please help me with the issue. Thank you
Hey learners, facing an issue with outlook, follow the below methods to fix the error 0x800c8101 Outlook error. You might be facing this issue for many reasons like blockage of the firewall or because of some missing registry keys or may be due to wrong e-mail settings also.
Method 1:
Check out the settings because the wrong email settings also cause errors.
• Go to Outlook, click on the file.
• Click on account settings.
• Click on change in account settings.
• Go to more settings, and click on the outgoing server.
• Tick on the checkbox, besides “my outing server SMTP requires authentication,” and “logon to incoming server before sending a mail” options.
Method 2:
Sometimes, the blockage of firewalls and antivirus software may be the reason to fix them follow the below steps.
• Click on programs in the control panel.
• Click on uninstall programs.
• Select Firewall and antivirus software in it and uninstall them.
• Junk files of the software are deleted.
• Restart your system and use outlook.
The above methods work for all the versions of outlook. Thank you.
