How To Fix The 0x803f7001 Error In Windows 10?
I purchased a new laptop with Windows 10 already installed. When I booted for the first time, I received the 0x803f7001 error. The error means Windows is not activated. What to do?
The error 0x803f7001 can be gone if you enter a valid license key. Since you have got a new laptop, try this –
a. Go to Settings.
b. Open Update & Security.
c. Go to Activation.
d. Click on Troubleshoot.
If you have the product key –
a. Open Settings.
b. Go to Update & Security.
d. Click on Change product key.
e. Enter the product key.
f. You will activate Windows.
Since this is a new laptop, you can contact the retailer and the manufacturer if the problem persists.
