How To Fix The 0xc00000185 Error In Windows 10?
Recently, I upgraded from Windows 7 to Windows 10. I am encountering a 0xc00000185 error when I start my laptop. A blue screen appears, and I am unable to boot into Windows. How to fix the error?
First, disconnect all the external hardware, such as USB, LAN cable, keyboard, mouse, etc., from your device. Boot into Windows. If the error does not appear, one of the hardware is faulty. Connect the hardware one by one, and restart the system to find the culprit.
Follow these steps to fix the 0xc00000185 error if the issue persists –
a. Insert the bootable media (installation media of Windows 10), and boot from there.
b. Select language, time, and keyboard, and click on Next.
c. Click on Repair your Computer.
d. Click on Troubleshoot.
e. Open Advanced Options.
f. Click on System Restore.
g. Complete the process.
h. Boot into Windows.
The above error often occurs due to hardware failures. If you are not able to solve the error manually, you should visit an expert.
Notifications
