I bought an Asus laptop recently and it was working fine but now it is not starting. I get 0xc00000bb error and then a black screen and nothing happens after that. Is my Windows broken? The computer just doesn’t start. What should I do?
How To Fix The 0xc00000bb Error Black Screen
From your description of the situation, I know that the problem is serious. If the system refuses to boot, it is serious almost every time. The error code that you are getting 0xc00000bb error usually occurs when there is a BIOS error.
The error code indicates that there is some problem with your motherboard’s BIOS. This can happen when you incorrectly flash your BIOS or mingle around with it. Unfortunately, because the issue is with the BIOS, you cannot do anything yourself and all you can do is call up the manufacturer service. If the product is under warranty, the manufacturer will replace your device.
