I bought a new laptop and a genuine Windows product. When I am applying the Windows product, the process ran for a few minutes, and then displayed a 0xc004c060 error. Is there any way to fix it?
How To Fix The 0xc004c060 Error While Activating Windows 10?
If you are getting the 0xc004c060 error, it might happen the retailer from whom you purchased the key has given you a duplicate product. You should go with your laptop to the vendor and show him the problem. Take a refund for sure!
On the other hand, if you have purchased the key from a Microsoft store, contact Microsoft support.
I am suggesting a few ways. Try these out, and if your problem persists, do as I said above.
Method 1
a. Press Windows + R on your keyboard.
b. Type ms-settings:activation and press enter.
c. Click on Troubleshoot.
d. Apply the suggested fix.
e. Restart your device.
f. Activate Windows.
Method 2
a. Type command prompt in the Windows search box, and open as Administrator.
b. Type slmgr /ipk **. Replace ** with your key – Press Enter.
c. Type slmgr /ato and press enter.
d. Restart your device after the process completes.
e. Your Windows 10 should be active now.
