How To Fix The 0xe0434352 Error In Windows 10?
My laptop is behaving weirdly. It runs on Windows 10 and suddenly throws the 0xe0434352 error when I open certain applications. How to fix the error?
The 0xe0434352 error is really weird as there are no specific reasons for its occurrence. Here are some tips –
Method 1
a. Press Windows + R on your keyboard.
b. Type devmgmt.msc and press enter.
c. Go to Display Drivers.
d. Right-click on the items located.
e. Open Properties.
f. Click on update driver.
g. Click on the search automatically for the update.
h. Complete the process.
i. Restart your device.
j. The error must be gone.
Method 2
a. Go HERE
b. Select your language, and click on Download.
c. Tick the NetFxRepairTool.exe box.
d. Continue the process.
e. Open the downloaded file.
f. Click Next.
g. Click on the terms and conditions checkbox, and click on Next.
h. Finish the process.
