How To Fix The 3049 Cannot Open Database Error In MS Access 2016?
I am unable to open the Database in MS Access 2019. I am encountering a 3049 cannot open database error. I am learning Access, and I need help to solve this error.
There is a built-in repair tool in Access that can help you fix the 3049 cannot open database error.
Method 1
a. Open Access.
b. Go to Tools.
c. Click on Database Utilities.
d. Click on Compact and repair.
e. Select your Database.
f. Click on Repair.
g. Restart Access.
Method 2
a. Open Access.
b. Click on File -> Open.
c. Select your MDB access file.
d. Click on Save and Publish under the file tab.
e. Change database type to Access Database (*.accdb) in the File type option.
f. Save the changes.
g. Open Database.
