How To Fix The 805a8011 Store Error In Windows Phone?
I have a Windows phone. I am getting an 805a8011 store error there. The error persists while using the mobile data as well as Wi-Fi. How can I fix the error?
The 805a8011 store error can occur due to different reasons. I will tell you all the ways to fix the error known to me –
Method 1
You have to make enough space for new apps on your phone memory. If you have space in your external SD card, then transfer movies, photos, etc., or delete them to make space in your phone memory.
Method 2
a. Go to Settings.
b. Open Time and Date Settings.
c. Make sure you have the correct time and settings there.
Method 3
a. Go to Settings.
b. Open Email + Account.
c. Click on the Microsoft account and hold it.
d. Click on Synchronize.
Method 4
a. Press the Volume button and the Power button for a few seconds. You will get a vibration.
b. Wait for the device to restart.
c. Access the Store.
Method 5
This will reset everything on your phone.
a. Open Settings.
b. Restore your phone.
c. Click on Yes.
d. The phone will restart.
